EVENING OUT
- Jun 21, 2017
- 34
Hello, I am new to this site. Trying to figure it all out. I have a 2003 Mercury 75 HP ELPTO outboard. I have had it a little over a year. Supposedly the outboard was rebuilt. Not a lot of known history on this pig. I do know I had the carbs cleaned and rebuilt prior to last summer. Before this season I have changed the water pump impeller and plates. Spark plugs changed, primer bulb changed. (not related but lower unit oil changed). The first time or two out on the water (salt), motor ran great, no issues. The last 2 times it idles fine and runs at WOT for about 5 or 10 minutes and then bogs down. We were close to where we wanted to just idled to the location we were going and hung out for the day. Motor starts right back up and again, runs about 5 to 10 mins and then bogs down. By then we are back at the ramp and on our way home. No issues running this pig in the driveway on the hose and muffs. Any ideas? today I removed the thermostat and the poppit valve. Can't tell anything by looking at the thermo, but I am picking up a new one tomorrow and replacing. The poppit valve diaphragm looked beat up and had some holes and roughage. Would the poppit valve cause the motor to bog down. I never had an overheat alarm, the tell tale was spitting nicely. Don't know if alarm work. I do have a water pressure guage and that is always about 10-20 psi depending on RPM's. I do have a temperature guage, but it never reads anything so I don't know if that works either. Also I did notice that water was expelling out of a small hole on the thermostat housing. See pics. Any advice would be greatly appreciated. Thanks.
