Tell Tail issue: I bought this used, and have replaced oil filter, oil, spark plugs, gear oil, impeller. Engine starts fine but notice that tell tail does not pee, only exhaust fume comes out (hot air). When engine is idling, water comes out between port cover (starboard) & adapter (slightly above lower unit & gear housing)
Things I have done and validated:
- impeller is properly installed with pin in correct position.
- coupler from water pump to engine water tube is correctly connected.
- hose between engine & tell tail is clear of clogs
- blow water backward from tell tail into engine and water comes out at bottom section (slightly above the lower unit).
Manual says that engine has to be warmed up before the tell tail appears, but I am afraid of running engine too hot (I did let it idled for couple minutes max, and no pee).
I also temporarily removed the thermostat: and still no pee.
My plans:
- Remove the thermostat cap, and let engine run to see if water comes out from there.
- Blow water backward from tell tail with thermostat cap remove and see if water comes out from thermostat.
If anyone has any other ideas, please help.
Thanks
Tuan
My plans:
Thanks
Tuan
