I have a 1999 150 hp oil injected v6 mercury. I noticed small oil slick around motor after tying up in slip. When I removed shroud I noticed oil reservoir was very full.Somehow I don't remember it being that full before but I checked hhe cap and it appeared tight. After moping up oil in bottom cowl I looked on line and saw a 3 psi check valve in system by vent tube. If this check valve is shot would it cause oil to leak out vent tube? If not what would ? Thanks.
