Please see the video for a demonstration of the problem: https://www.youtube.com/watch?v=v7Ht2x4NM80
As you can see, the timing advance lever is not moving through its full range of motion, because the trigger will not advance enough. I ran into this problem while doing link&sync: found out that the max timing was at 23 degrees BTDC and I was trying to correct that -- (28 BTDC @cranking speed is correct for this engine) but obviously making any adjustments was impossible, since the lever was not going all the way.
I'm posting because I'm wondering, why my WOT RPM is only 2000 (I bought the engine as faulty, the previous owner said it "will not rev properly" and I accepted the challenge for a reasonable price). So in addition to the RPM being limited to around 2000, the engine misfires intermittently during WOT. Idling in forward gear goes smoothly, no hesitation or bogging. So I'm hoping the timing issue is behind this. I will proceed to pull the flywheel and sort the trigger out, if you guys think a difference of 5 degrees makes my engine act as described.
Compression on the engine is 115-120 PSI on all three cyls, carbs have been thoroughly cleaned and adjusted per factory manual, got new plugs, new fuel lines, new fuel filters (water separator + inside cowl), cleaned and filed all grounds nice and shiny, put in a new impeller as well. The fuel pump had been serviced w/ new gaskets by the previous owner. I have checked out all wiring and everything seems OK. So I'm really, really hoping the limited timing advance is the issue with this one.
EDIT: The engine is a 90hp 3cyl 1991 model, carbed, made in Belgium (serial 9570635)
