angelo3658
- Jun 22, 2016
- 19
I am new to the forum and hope that I can get an answer to something that I read on an archived post. I'm working on a 1973 Mercury 7.5 HP, S/N 3733058, which won't start. Has a weak intermittent spark on both cylinders. I'm rewiring and trying to set the points. In the post it said to watch the flywheel marks when checking ohms on the points. Are the flywheel marks I & II supposed to be in a certain location when the points open or close? The only thing I can tell on the ohmmeter is when the points close for each cylinder, which appears to be about 180 degrees apart.
Thanks for any help.
