RandyJ
Master Chief Petty Officer
- Jun 13, 2002
- 808
Hoping I'm just overlooking something simple and stupid. Fuel is getting into bowl but none in carb. When I spray starting fluid into carb it starts right up. This old motor was running as good as new. I let it set on my pontoon out in the lake for a couple of months and when I tried to start it would not run. I pulled it out of the water and found lots of water in the gas. After cleaning the whole fuel system it ran ok on trailer. When I put it in the water it would not start. Again I found more water in the tank. Now, i pulled it out again and cleaned the carburetor and whole fuel system as I've done many times before. It simply is not sucking fuel into the carburetor from the bowl. Any suggestions as to why?
