theboatman69
- Jun 2, 2017
- 23
Hello all,
I have a merc black max V6 135hp outboard. When i first take it out on the lake it runs beautiful and smooth at about 5000 rpm WOT. after about 45 mins, it wont go over about 3000 rpm and starts running rough if I push it, but runs just fine at 3000 rpm. So i got into the forums and started checking the fuel delivery system. I changed my bulb out about a month ago as it was old and flat when i was out on the lake. So it the bulb has been good since. Bulb was hard when i squeezed it but now i don't get that "hard" squeeze when i squeezed it. Seemed like air was in there so i took it off then siphoned the gas back through and its good again. I think it ran pretty low in gas in the gas tank when i was trying to get the old fuel out so maybe it was an airlock? does this sound right? Anyway i decided to take off the spark plugs to have a look. On the port side they are nice and clean but on starboard its another story. All 3 were covered in carbon. I took some contact cleaner and cleaned the plugs and I haven't had a chance to go out to the lake again to try. its had clean fuel since i changed the bulb. I have read a lot about coil and stator problems when this power loss is occurring. What is happening? Is my engine heating up and something electrical is breaking down? Whats with the carbon build up on the one side only? Are we talking switch boxes, coils or stator or maybe everything? I don't really know where to start at the moment and I don't think the fuel delivery has anything to do with it because it was doing the power loss thing even prior to bulb change and when the bulb was good. The guy I bought the boat from suspected there might be a coil issue sometimes when he ran it last year and now this year after winter, it probably did it in you think? Any help is appreciated guys cause when i read the forums about this issue it seems there are mixed things happening to the engine. Maybe the carbon build up on starboard side is and indication or hint of where to start?
