A motor from just about any era can charge a motor, it just depends on if it has a charging system and if it's in working condition.
Most electric start motors have a charging system, it may not put out many amps, but it will charge.
Measure your voltage at the battery prior to starting the motor, then measure with the motor running, as the RPMs increase so should the voltage.
