theboatman69
- Jun 2, 2017
- 23
Hello all,
So i know that rectifiers have been beat to death. I have read the forums. So let me just start here. I bought a used boat, 1981 Deltacraft 170 xlt with a nice running 1987 mercury black max 135hp outboard engine. The tach was not reading. So after reading forums i discovered that the rectifier must be screwed or stator. When i took the cover off to examine the rectifier, I discovered it was wired wrong!!! Very wrong. On the 2 AC terminals the 2 yellow wires were tied together on one terminal, the grey wires was just tied to one terminal with a yellow/ red stripe wire? and there are 2 red wires on the positive terminal So i did a diode check, fixed the tach and now its reading. Now the wiring has one yellow, and the grey tied on one post, one yellow on one post, 2 reds on the positive post but my question is where does the yellow/ red stripe wire go? when i trace it, it goes up to what i believe is a regulator or maybe idle control box (but im probably wrong). It has the red wire from the positive terminal of the rectifier, and the yellow/ red stripe wire on it. PS the color might me faded. its a lighter color than the yellows so maybe a white and red stripe or black stripe faded to red?? Thank you for taking the time to read this.
