opalized1
- Apr 5, 2017
- 64
motor has sat for 10 years im sure, I just got it, installed on my boat, changed lower unit lube, replaced impeller, then put it in the water and ran 10 gallons of gas through it with sea foam and proper mix 50/1, most of the running was at just above idle ran fine, trolling the lake for sharks. anytime I attempted to get full throttle out of it, the boat would only achieve maybe 10 to 15 mph, with a noise similar to detonation, or popping, a check of linkage its achieving full throttle at carbs, distributor is rotating, spark advance, everything was greased and movement checked, a secondary not, I have tons of water coming out of prop, and vents below water inlet, but none coming out at 2 top weap holes, a check of motor after running there is no heat in the area around sparks plugs or any of the 4 sides of the motor, 2 sides literally cold, and the exhaust and spark plug sides slightly warm, but you can hold your hand on them without getting burnt, after the first day, I brought it home pulled plugs checked compression, 90 lbs on all six cylinders, replaced plugs with new, and return to lake next morning with a second tank of fresh gas, pre mix 50/1 and more sea foam in gas, ran the same way all day, minute improvement at times could be heard in just of idle tone, but exactly the same at wot, seems to have great spark, I pulled a plug wire while running and got the shock of my life, the fuel tank was spotless when installed fuel filter shows no debre at all and carb fuel filter is spotless, any thoughts, I will be returning to lake this weekend to run some more gas through it, I had removed plugs after second day out, and soaked cylinders with sea foam, with motor up, the motor fires cold just fine, restarted once warm without even rotating a full turn, runs great off idle, just no top end
