singletrack_mind
- May 29, 2017
- 6
I am not an experienced marine mechanic, but I have been asked to install a new throttle/shifter on a friend's boat. The previous unit was not correct for the application and had also been removed before I saw the project so I was not able to infer anything from that installation. I can't tell which way I should have the shifter set up: I can't tell if the gear selector on the engine gets pulled forward from neutral into forward running, and pushed to the rear for reverse, or if it's the other way around. Currently I have the control installed, and it locates neutral correctly and can be shifted both directions with my friend turning the prop so the gears will engage, but once it's been shifted I can't tell if it's in forward or reverse.
The control I am installing appears to be correct for the boat; all it's wiring harness colors correspond to the boat's. Other than that I know nothing about it, it doesn't even seem to have a brand or model name anywhere on it. It appears to have alternate control cable connections for both throttle and gear that would allow either one to be push or pull. There were only two control cable retainers though, so I chose to install the cables in the positions where the retainers were. That turned out to be wrong for the throttle, which appears to need a "pull" cable action instead of a push. That makes me wonder if I have the gear shift cable in the wrong place too, but I don't know how to tell since I do not have access to water, so can not run the engine. How can I figure this out?
This is a 2004 200HP 6-cylinder engine, family # 5M9XM02.51C0
Thanks for your help!
