mickyryan
- Apr 18, 2016
- 4,210
so I have a issue with this merc, I have cleaned carbs, set floats, checked needle and seats, fuel tank rebuilt fuel pump , replaced fuel lines, adjusted the carbs, compression is 125 on all 4 cylinders within 3 across all 4.
I checked to be sure pointer lines on properly with 0
can get it to start and idle but putting into gear it stalls , I have attempted to adjust timing as per instructions ,
not hi speed but the low speed, however I cant get it to go any lower then around 7 btdc (starts running like crap)even though the sticker on the cover says initial timing 4 degrees atdc.
the engine is new to me so not much known on what some one might have misadjusted before or whatever,
I took steps to adjust 1st pickup by looking at where the carb starts opening with the sliding action on the lever, then I set the throttle idle
screw just before that
then I took and set timing for 7 degrees because I had read that the first pick up and the advance at that point should be 7 degrees, engine was revving about 1500 so I backed idle off while in water to 900 it ran fine but then I had to advance timing again because it was running rough so I did it by ear when everything seemed smooth I was around 1100 rpm, I tried shifting it just stalled ... I'm at a loss and I think I am doing this wrong . the fast timing stop is set at 23 degrees as it should be.
