khunter570
- May 26, 2017
- 3
I just made my first attempt to change the impeller on a 1994 Mercury Tracker. Everything seamed like it was all good until I tested it buy selecting through the forward/neutral/reverse. The boat goes into forward and neutral fine, but will not engage reverse. I dropped the lower and attempted to manually access reverse, but it seams like the gearbox has two forward gears in stead of the reverse. I also changed the gear oil, but it was more like adding gear oil because when I drained the old oil, I only had some water drain out. Any help is appreciated. It has been a few days trying to figure this out.
