jschilling
- Jul 10, 2008
- 1
I have an issue only at idle, anything over 1000 rpm the engine runs great. I have had this problem from the day I bought it used as a repo. Hot or cold, engine stalls after 20-30 secs of running as if it is out of gas, I can immediately start it back up and it runs strong but dies again 20-30 seconds later. Dealer could not find anything wrong with it. I have cleaned injectors, VST, changed gas, plugs, fuel line, fuel filter, low pressure fuel pump, IAC, and battery. Fuel pressure is a constant 40psi and ball is hard. Only thing I notice is that the fuel filter bowl is not always completely full. This issue always happens in no wake zone and has been going on for 8 years, I have just dealt with it as a minor nuance but I would like to get it fixed. No other issues running at all, just idle. I am fully aware of the vapor lock issue after running hard on a hot day and I deal with that also but I have learned to minimize that. Anyone have any ideas what to check next, I am at a loss. Thanks.
