ThomW
- Aug 8, 2016
- 615
Hello again everyone. I am almost done re-rigging my boat with the new-to-me 2000 Merc 200hp motor I purchased. The last thing (I hope) holding me back is the trigger assembly. The wires for the plug end of the assembly are shot, so I'll need to pull the flywheel and replace the trigger assembly. Here are my questions:
1. Do I need to mark the flywheel or anything before I start the removal process to ensure it lines up correctly after? Or will that not matter for re installation purposes? I don't want to screw up the timing or anything else. I know I hold the flywheel and remove the one nut, then use the puller to pop the flywheel off, but does it matter if the flywheel turns a bit when trying to get the first nut off?
2. I have the merc flywheel removal tool, so that shouldn't be a problem, but once the flywheel comes off, how do I remove the trigger assembly? Do I need to pull the stator first? Anything I should pay attention to or look out for when trying to remove the trigger assembly and/or when I go to install the new one?
Many thanks as always!
