briwi
- May 18, 2017
- 3
So, I got a killer deal on a boat and a motor. The only thing is that it had been sitting for a year - a young guy like me can handle that...right? Sort of.
Got her running fine! Needed some new plugs, a new fuel filter and she was purring away. She doesn't exactly run...clean. Definitely running a bit rich so I need to tune up the carbs, being at 7,500ft above sea level doesn't help much. Now, the guy who I bought it from said that he had his mechanic clean the carbs, but when I prime the engine there is some fuel leakage out of what seems like the bowl. Do I need to rebuild the carbs?
Onto the other issue. I drained the gearbox oil, and there was water in it...damn. Should I pop the whole damn gearbox assembly off, or just try and replace the oil seals on the prop shaft? This is where I feel the work is above my pay grade and I should just hand it off to a mechanic. That being said, I'd love to get her going myself, but not spend a fortune on tools that I will never really use in the future.
Last but not least, does anyone know where I can find a manual for this outboard?
Thank's for checking the post out and glad to be apart of the community!
