Hi, I'm trying to determine the source of a water leak that seems to be coming from the area near the exhaust manifold. I sprayed some fogging oil into carb and saw no evidence of an exhaust leak from that area and nothing that indicates any water in the cylinders. Engine pumps water well and runs good otherwise. I also checked to make sure it wasn't coming from the water jacket around the plugs. The temperature of the water leaking from cowl is about the same as the water coming out of the "pee hole". Any thoughts or ideas? Thanks
