Hello,
I've been trying to finetune my '88 merc online 6 115. This is the second motor of this type I've had and both have behaved similarly.
On this one, it is timed perfectly, all cylinders have good compression. I have rebuilt the carbs. Everything is set up per the manual to fine tune the idle setting.
I have had a really hard time getting a good idle setting between neutral and in gear.
If I follow the instructions and fine tune the idle jets, and reset the idle stop to around 800rpm, when I put it in gear the Rpm are too low and it will typically die. I know you want your neutral below 1000rpm, and I can get it to about 900-950 at the lowest without the motor dying when I put it in gear.
I have gone through the procedure multiple times and this is about as conservative as I can get it, which. I know still beats up the gears.
The other thing is that after WOT the idle jumps up a bit, to around 1100. It will eventually drift back down, but again, it makes it hard to definitely set your idle correctly.
I have not checked the idle stabilizer. That is the only thing that jumps out as a possibility, but I find it odd that both motors operated almost exactly the same, and it makes for a stressful docking!
Anybody have wisdom on this area? Is this the deal with these motors? They run great opened up. Would be nice to have an idle that wasn't chewing up the gear box
Thanks in advance
Is
Thanks in advance
Is
