GreedyMuffin
- Jul 1, 2016
- 97
Hi!
I got an Alicraft 18 Norwind.
Something is off and I only get 28 knots with 90HP, while others are reporting 33-35 with 90HP on the same hull. (It is a light hull, only 500KG).
I saw this great deal on a 2004/2005 Mercury 125HP 2+2 engine, two-stroke. I got the two-stroke classic as well.
With 28 knots, at 5400 WOT the engine is using around 38-39L, but on cruise (18-19 knots if I remember correctly) at 3500 it is only using 17-19L.
Would a 125HP at around 20 knots use more fuel at the same speed with a lower RPM?
Have anyone got any experience with these engines? My engine is stable at 7.5 bar on all cyls. Starts first try and is a solid engine!
Would it be a dumb choice to "re-power" with that engine? Fuel is around 1.63 USD pr liter, or 6.2 USD pr gallon of fuel here in Norway.
Thank you!
The 125 is cheap. Very, needs an service. I will test comp. and I can fire ut up. So I do not know the condition, but looks decent. I could perhaps make 500-600 USD from "upgrading".
Anyone know what sort of consumption at what RPM it is drinking? ex. at 5250 it is 50L, 4750 38L, 4250, 32L, 3750, 26L, 3000, 20L etc.
Thank you!
