So I checked and cleaned the float, bowl and seat. When I pump the ball, gas shoots out of a hole at the top right corner of the carb. This hole has a slot so it is removable for some reason. Help! Anyone know why it comes out of there instead of keeping the priming ball hard? It's spraying gas into the engine case. Not good. When I blow into the gas line and lift the float it does seal good. Thanks in advance for any guidance.
