1994 25 HP Mariner water pump issues
I have a 94 25 HP Mariner that looks like brand new probably less that ten hours on motor. While running it the water pee hole would dribble then pump good stream running down the lake once stopped it would dribble pump good stream but just not good stream 100% of the time. So I ordered a new water pump and put it in the old one has a set in the wheel ends from just sitting not running. Now I still do not get a full stream all the time it dribbles then puts out a full stream for maybe ten seconds then dribble then again start to put out a full stream. This was sitting with motor in water at boat ramp. So I brought it home put on water hose and ran a week eater cord up the pee hole and maybe it helped some but it would run full stream then dribble then go back to running a full stream. I held my hand on the motor and it never got what I call hot I could still keep my hand on it after running for a few minutes I just cut it off and need to know back in 94 did the 25 HP mariner put out water like this as being normal. The O ring around where water pump goes was good put some black 3m gasket seal around and put O ring back in place after cleaning around where O ring went. Water pump went into place well just can not figure it out. Big question is this normal do not want to ruin a really nice older motor such as this is. On my Yamaha 25 the pee stream was stead all the time but on this Mariner it is not. If normal O.K. if not tell me where to look to see if I can find the problem. I do not have a book.
