Hi there, I have replaced the water pump/impeller in the lower, ran it in a bucket and with muffs, not getting any water out of the tell. There is a tell at the top of the block( behind the yellow circle, under the cowl), there is a small nipple that leads to a black hose that runs down the starb. side of the motor to a rubber grommet where I assume the water will leak out letting me boat with confidence.. Well, not happening. I removed the small nipple and ran the motor for about 5 minutes in the bucket, revving it occasionally, ans still no water from the opening. I am getting water sprayng out of the exhaust. When i remove the black hose in the center of the photo (Blue circle), I get a stream of water going through it. i guess my question is, do I worry? Do I plug the tell hole and just hope for the best? Can I unplug another bold in the block that is along the cooling to reattach the tell to that one?
https://goo.gl/photos/itxXLy2tCPrbYMxH6
thanks for your time in helping me out...
-Steve
-Steve
