I have a 1997 25hp mercury that today while on the water decided not to go in reverse. I was putting around the dam and it stopped going in reverse.
Neutral and forward work fine. I pulled of the cover and checked the shift linkage. I pulled the shift linkage off and the cables all worked fine.
The cam closest to the front of the motor that the shift linkage is hooked to will not move back to go in reverse. I have only had the motor for a week.
I was going to try and do a water pump change myself. But adding this problem worries me. Can anyone help?
Thanks'
Thanks'
