I need some help, I am having a hard time trying to identify the issue with my lower unit. When at 3/4 wot I turn about half to full turn and when I do this three quarters through the turn the motor revs up and the boat slow down I pull back the throttle the first time to 1/4 and then the second time to 1/2 the motor then starts to accelerate again to full power. This only has happened on turns always at the same point in turn my dad was with me both time and thought that the prop came out of the water but the prop is a good 6in below bottom of the boat (top of prop) and it is a extra long motor. It has only happen 2/20 times I took it out. Do you guys have any ideas and could you tell me how to check for that.
I found out last fall that there was water in the gearbox only about a tablespoon and milky oil so I drained and put away. Could the water be the problem??
