I was having issues starting the motor. Did some test and determined the solenoid was bad. I replaced the solenoid and it cranked right up. I let it idle for 15 mins or so. Turned it off and let it sit for 5 mins. When I turned the key I heard a pop and smelt smoke. For the next 20 minutes I started checking wires and fuses. Found nothing. I also noticed the voltage gauge wasn't reading any voltage and the motor trim didn't work. After checking wires an testing fuses I went back and tried to crank it. It started up. The next couple days I would test throughout the day and all was good. Today, no voltage at the gauge and no power at the motor tilt. Again looked for burnt wires or wires that my be shorted out. No luck. But now it's running again. I have not pulled the flywheel to examine the stator or the trigger. Any advise would be great. Thanks
