Renoluck918
- Mar 19, 2017
- 2
Hello everyone,
I'm new and have a serious mind puzzle involving the oil alarm on my 1989 Mercury 135hp Blackmax.
Let us start with I have a brand new out of the box control module installed correct with no change.
Now for the fun...
When I turn the key to the on position without cranking the engine the oil alarm beep beep beep sounds. There is no system beeeep beep beep to say normal operation. Yes the oil is full the cap is new also. I when through the system one component at a time unplugging first the oil cap from the controller then the rotation sensor and then the green wire from the switch box (power pack). I then removed all components in the circuit. All actions maintained the beep beep beep. If I unplug either purple or brown it goes quite. Which with no power it should. So, now that I installed the new controller and went through all the troubleshooting again without any change I'm left scratching my head.
If anyone has any thoughts or a detailed troubleshooting method I may not be doing correctly please help me out. Thanks for all the help
Now for the fun...
