I have a 4.5 hp I acquired partially unassembled . The lower unit is off with the water tube disconnected. How do I get the water tube installed back in the leg so I can attach the lower unit? Is the a way to align it?
There should be a small tube protruding from the water pump, facing upward. That tube mates with another tube that is within the drive shaft housing. Basic hand-eye coordination aligns them when the lower unit is inserted into the drive shaft housing.
The copper tube is held in at the top by a grommet.------It also has a washer up top.-----Some will argue here.---The factory original washer was plastic and has been known to melt and block water flow to the engine.-----I would advise to remove the powerhead to replace the grommet / install the water tube and install a newer / improved factory washer.----Not hard to do.
