Hello Again.
I've been working on my Mercury outboard trying to solve a rough idle issue. I have removed and cleaned both carbs, replaced the stator and trigger which had corroded wiring and changed spark plugs and wires. I finally I checked cylinder compression with my Bosch tester. The gauge showed a consistent 120 psi across all four cylinders. I'm not sure what the specs on compression should be but a consistent 120 psi shouldn't be bad. I have ordered a coil assembly. The main issue is that the motor runs rough at idle, but powers up and runs smooth at full throttle. Does anyone have any other ideas? Thanks a bunch.
