AnthonySci
- Dec 4, 2016
- 35
Four months ago I bought this 1998 electric start Mercury outboard with tiller from a Seattle mechanic---the motor was already warm and running when I arrived. He said he'd rebuilt the carb, changed the oil & filter. The motor ran normal. Before I left, he disconnected the gas line and ran the motor out of gas.
Now very difficult to start and when I am able to get it to fire, it runs at most for 15 - 20 seconds, then it dies. I've been setting about 1/4 throttle. Full choke, 1/2 choke, no choke doesn't seem to change the rare occasions it does start.
I've got NEW non-ethanol gas, new plugs. Primer bulb stays hard.
Today, I pulled the carb apart: gas was in the bowl. Main jet, pilot jet, the needle valve---all were clean. When I manually pushed down on the diaphragm plunger--it squirts gas.
Where should I set the throttle for cold starting?
Serial no. 0G 697 665
I appreciate any help
