Hi, I have some questions about the differences between models of 2.0L engines. I have worked on a lot of smaller engines (1-3 cyl) but this will be my first v-6 repair/build.
I have a 1987 2.0L Mercury 150 that blew up and wrecked the block. I took it apart and saved what I could and junked the block. The electrics have the 1/2" ply stator (vs 5/8").
I also have a 1979 2.0L Mercury V-175 in pieces that we have had around for years. Most of the wiring is rotten on it but there are still some good parts. The power packs have a different part number; 332-5524A1 (1979 - 175hp) vs 332-7778C (1987 -150hp, 1992 -200hp).
I ended up buying a new 2.0L core power head that someone had sitting around for a while from kijiji to fix it. He didn't remember/know anything about it really. The power head is stamped 12/94 so I'm guessing it's a 1995. It had some interesting differences from my old motor so I wanted to figure out what's going on. After doing a lot of searching, measuring and comparing part numbers I believe I have a 1995ish 2.0L V-135. The head part number is the same and it has the same intake configuration.
I also picked up a blown up 1992 2.4L 200 as the guy pretty much gave it to me lol. Its block has a giant hole in it, it's missing one of the power packs and the trim motor. It is an XL mid section length also, so the mid is no use to me. It had the horizontal intake parts I needed though. I also liked the cowl and thought I might be able to use it and some other common parts if I need them.
Differences I can see so far:
The heads are one piece instead of 2. The part number is 18787-04.
The old intake/reed cages were mounted vertically and the new motor has them horizontal.
The old motor had the coils mounted on the exhaust back plate and the new motor doesn't have the same holes and mounts. New motor only has 4 threaded holes. Also the new exhaust back plate has one less bolt on the bottom of the cover.
Mounting for other electronics like voltage regulator are missing or the holes are there but not threaded. There are other mounting holes but they don't line up to my 150 electrics.
Questions:
What are the differences between the 1987 150, the 1979 175 and the 1995 135 being as they are all 2.0L engines? Is it just the carbs, tuner plate and heads?
When I look at the '95 V-135 parts drawings I noticed that the coils and mounting plate for the 2.4L 200 seem to be the same as the 1995 V-135. Is it ok to just use those in my 150 electrics? The other parts of the electric system are different except the power packs.
I'm not really sure what parts are best to use to build this motor. Can I just figure out new mounting for all the 150 parts and run that system?
I bought CCMS fiberglass reeds for the motor. Do I need to change the jetting to compensate for the extra flow if I don't port and polish the cages or modify the tuner plate?
I was thinking of porting and polishing the reed cages and tuner plate but was recently told not to bother as it robs mid range power. I might shave the heads 30 - 50 thou to make the motor run better. I'm assuming these are de-tuned to bring the 150hp motor down to 135hp?
Parts I have to use:
3 sets of carbs, all look the same but one set is from a 2.0L 150, one from 2.0L 175 and one from a 2.4L 200
2 lower units, one 1.87:1 gear ratio and one 2:1
2 power packs 332-5524A1 (175hp),
3 power packs 332-7778C
Complete electrical system for 1987 2.0L 150
Complete electrical system for 1992 2.4L 200
Some electrics from 175 2.0L.
1987 20" mid section with 3 ram trim that leaks down badly
1992 25" mid section (need 20") with newer style trim that works but is missing the electric motor.
I'm mostly concerned with the electrical and fuel system at this point but I thought I would give the full story so it's all there for better advice and future reference.
Thanks very much for any help,
Reefsider
Questions:
Reefsider
