AGENT 37
- Mar 2, 2007
- 319
I ordered a tiller kit to convert my remote control/electric start 1A3G312EK model 30hp EFI four stroke to a tiller steer and got the 898103A92 co-pilot kit with it. While I was attempting to install this kit I realized that the 8mm bolt/stud that screws into the swivel bracket was too small to grip the clean new threads in the swivel bracket hole. There was no paint on the threads in the hole, they are not damaged, and no co-pilot has ever been installed on this low hours motor. when installing the bolt/stud it threaded very easily and felt sloppy so I pulled on it to check tightness and it pretty much came right out I was also able to gently push it all the way through and have it fall out the bottom of the bracket so the hole and threads are uniform all the way through the bracket. Am I correct to assume that it isn't supposed to be this way? Is there possibly a different kit with a different size swivel bracket bolt that I need? I also thought it was interesting that the co-pilot washer that has a key to lock into the swivel bracket has a 10mm oval hole in it, all other hardware has fits the 8mm bolt including nylon washers, metal washer, nylock nut and matched hole of the co-pilot handle.
