SPLMAXSAM
- Oct 24, 2010
- 137
My friends and I rebuilt a 1 owner great compression 1979 Mercury 140hp Tower Of Power outboard. It is the 1st generation of electric ignition. We rebuilt the carbs, replaced wiring harness, internal fuel lines, fuel pump gasket , and spark plugs. I have had the problem pretty much since splash 1/6/2016. What happens Motor starts fine after bout 5 ball squeezes and throttle advanced. Runs smooth at low and medium throttle. At wide open throttle: A) motor bogs down and eventually speeds up and then bogs back down B) fuel line and ball collapses What i have tried to resolve the issue 1) changed spark plug wires 2) removed fuel filter 3) changed fuel bulb 4) switched fuel line to non collipsible fuel line 5) open fuel fill latch to allow tank to breath better Motor still bogs. If i prime the ball when running full throttle it will run fine Assimption - starving for fuel?
