I have a 2003 Mercury 40hp ELPTO motor. Got the boat on the water yesterday and noticed a bit of an issue. Last year when I would first start the motor, it seems like it wouldn?t be firing on all cylinders at first. I?d shut it down, re-start and it was fine the rest of the day. It only did this a few times. Now any time I fire up the motor, unless I just shut it down a few minutes prior, it seems be missing. It shakes really hard and sounds rough. I turn it off, turn it back on and it?s good. The motor also wants to stall out when throttle is applied, even after the motor is warmed up. Ill push the throttle down and it will bog or even stall. And once I get up and running, when I back the throttle down to stop the motor doesn?t turn down smoothly like it used to. It almost tries to stall again even while still going 15 mph.
Any ideas on what is going on or what I can check? Thanks for any help.
