225 opti hard start
loxboy1
My opti runs good once its running but if it sits more then a day its a bear to start, Fires the dies. Have to play with the throttle a bit to finally get it running, ive checked the tracker valve and the primer bulb is hard.
My old opti would fire right up no matter if it sat for a day or a month. Any ideas
If it i like my neighbor's 150HP Opti, it has a boost fuel pump for starting only. The mechanic has a fuel and air pressure gauge set that attach to the fuel and air rails to test for proper pressure when starting and running.
