dreamcamino
- Feb 14, 2017
- 6
Hello folks, I have a problem obviously. Any help or guidance would be greatly appreciated. I bought a boat, 1998 regal with merc 175 SJ. The boat had been sitting for 3 years without fire. I have flushed gas, pulled spark plugs and sprayed penetrating oil in all cylinders, cleaned up carbs, and recharged battery. Couple days later, started up for about 10 seconds on first try. Turned off because I ordered new starter because it had some corrision on armature center spindle and pinion assembled wasn't releasing. Starter came in and before installing, tried to crank over and no voltage to any coils. Any clues? I have replaced starter, voltage regulator, key ignition switch. I am waiting for my DVA to show up to get more precise testing. Yes I have checked all fuses and are good. Kill switch tested good between open and closed. Any suggestions would be greatly appreciated.
