Hi all, I have a 2002 opti 225 xxl (30inch shaft) on my center console. I put a rod through the block. I dont have alot of money so im just going to replace it with another used one.
I found one but its a 25inch shaft, can i just take the lower and extention peice off mine and put it on the 25inch motor making it a 30??
Also my boat is somwhat custom in the the orig owner gutted this answer hull and redid it from the ground up and enclosed the transom and added a bracket. It has always had the 30inch motor and runs good 55mph, how can i tell if i need the 30inch shaft or if i can just keep the 25inch the way it is.
Also i dont have a computer to check the other motor when i go to look at it, is this a bad idea? I will however be starting it and performing a compression test.
Please let me know as im scheduled to go look at it some time tomorrow.
Thankyou
Thankyou
