How far from all the way in should the jets be?
E eddy2419 Seaman Apprentice Joined Sep 26, 2004 Messages 47 Jan 21, 2017 #1 How far from all the way in should the jets be?
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,589 Jan 21, 2017 #2 1-1/2 turns off light seat ...+/- 1/4 turn
E eddy2419 Seaman Apprentice Joined Sep 26, 2004 Messages 47 Jan 21, 2017 #3 Thank you sir. My son is having an issue and has pretty much no money. I do not know carbs well either. Last edited: Jan 21, 2017
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 27,036 Jan 22, 2017 #4 You really should adjust them on the water, motor warm, fresh fuel and in gear at idle. It takes some patience to get all 6 of them set properly. That motor will run very well, if the timing and carbs are adjusted well.
