2012 Mercury 115hp 4 stroke.
The other day while fishing I noticed that I couldn't tilt up the motor. Couldn't tilt up from switch on throttle or switch on motor itself.
The curious thing is that the tilt works when the ignition is on. This is definitely a new issue and I often used the tilt switch while the boat was on a trailer and I was putting a motor support between motor and trailer.
I replaced both up and down relays but the problem remains.
I also replaced the 3rd relay which I believe is the master power relay, but the problem persists.
I didn't see any matches for this symptom here in the forum.
Anyone have an idea?
