oldglastron
- Aug 16, 2008
- 32
Hey there,
I'm having some issues, I have invested a lot of time and money into this outboard. A little history I have replaced the internal and external harness CDI on both.
I replaced the entire throttle assembly with a new replacement Merc control throttle assembly. Carbs have been gone through, fuel pump diaphragm update done
The bleed restrictors in the side cover replaced PSI in all four cylinders at around 140 psi. before I got this engine the distributor was replaced, I have since replaced the wires repaired the pickup under the distributor cap, new plugs fresh fuel with new Moeller fuel tank and primer. Prime bulb gets hard no fuel leaks.
My issue is I can go WOT boat planes out fine but mid throttle or full throttle the engine shakes at times like its miss firing it cleans up then does it continuously I have my timing light hooked up you can see a decrease in in engine speed then back. It does not this in test tank. I have checked top dead center timing belt location per my FSM. Running out of ideas. hope you have a few. (oh I have done a static linkage check with cables off)
