Engine will not run unless fuel sprayed into the carb so I purchased a rebuild kit. I notices that the primer plunger of the enrichment valve was stuck in the down position. It prevents me from using a screwdriver to remove the enrichment valve assembly. I read the manual for rebuilding the carb and it had scant info on the enrichment valve other than to remove it and install the new parts. So I am stuck at step one, removing the enrichment valve. I am not familiar with this type of carb so any help is appreciated.
