hey guys, im new here and got a question...I replaced throttle cable on 1996 nitro with tracker 175hp...the motor will not start now...it will turn over but not fire..my question is, can I make adjustments on the gearbox control cable so that neutral lines up correctly at the motor...right now it is slightly back of center of what I assume is a neutral safety switch? not sure...any help would be much appreciated...thanks
