ColdWeatherBoater
- Oct 16, 2016
- 1
Hello Everyone!
I just got a new (to me) boat and the motor has not been started in 15 years. It's a 1981 6cyl mercury 115 tower of power. I rebuilt the three carbs, rebuilt the water pump, drained the gas and oil and refilled it, and just generally cleaned things up. Started her up and she runs! I wanted to check on a few things I was worried about and see what the experts think:
1. The exhaust water seems to have either oil or gas in it in a fairly significant quantity. In the video below you can see what it looks like, my guess is gas but it's hard to tell. Am I just running really rich or could this be a bigger problem?
2. It smokes quite a lot. I think this is because I was pretty generous with the oil ratio. Or is this amount of smoke normal?
3. Does this seem like a pretty rough idle?
4. There is a small oil leak out the bottom of the lower unit when the motor gets turned off. It's black oil. I just put fresh oil in the lower unit so I'm not exactly sure what that is. Any clues you could give me to look for?
Here is a link to a video of it running: [this is after it was running for about 20 minutes]
Thanks in advance!
Thanks in advance!
