garland gaston
- Sep 28, 2016
- 8
Heard a whining noise coming from my boat. Noticed the engine was tilted all the way up, and tilt motor still running. I hit the tilt rocker switch located on the 115 hp Mercury motor, and tilt motor continued to run, trying to go up more. I then hit the tilt rocker switch at the drivers console to the down position, and the tilt motor stopped, and started down. Then, both rocker switches operated normal. About 5 minutes later, without being commanded, the Mercury motor started tilting up again, all the way, and continued to run. I stopped it again by using the console rocker switch, and disconnected the battery so the tilt motor would not burn up. Is the relay bad or could it be the switch, or something else???
