garland gaston
- Sep 28, 2016
- 8
Where is the tilt/trim relay located on a 1996 115 hp 2 cycle mercury outboard?
Thanks Texasmark. Found them. Mine are under an access cover that also covers the coils. My problem was the tilt was going up as far as it would go, and the tilt motor was continuing to run, all unattended and without command. I disconnected the battery to get it to stop, as the remote rocker switch on the main motor would not stop the tilt motor. At first I thought it might be one of the tilt/trim rocker switches, but decided it was probably the "up" relay. Do you agree the problem is likely the relay?
