I purchased a 1995 parts motor to repair my 1998 (seems the parts I need match), both used in salt water exclusively. I am disassembling the parts motor now and experiencing the typical corrosion and oxidation issues. At this point I am trying to remove the power head. I am pretty sure I have all the bolts and nuts out, off or loose but nothing is separating. I mean not even the slightest gap between the power head and spacer or spacer and mid section, its not moving, like there are still bolts in place. The three bolts on the carb side that pass thru the spacer and thread into the mid section are loose and free so its not those. I suspect the 4 studs that thread into the power head and pass thru the spacer and mid section are locked in with oxidation to either or both. After working off the back of my truck with no luck I hung it by the mid section from a tree to use the weight of the power head to my advantage. I heated the areas of the spacer and mid section where the studs pass and whaled on the studs but still no movement. Any thoughts?
I will try and post some pictures tonight. Sad part is I will have to go thru the same process with my motor to put these parts on (not looking forward to that). At least I have this one to learn by.
