I'm new here and I was wondering how I need to post to get a lot of responses
Which I don't can anyone help
I'm confused. Every one of the posts you've started has responses. Some only one reply, others have more. You don't need a lot of replies - You need replies that help you.
Another thing is several of your threads were started in the wrong section, for example Evinrude questions in the Mercury section. I moved all that I found into the correct section. If a thread is in the wrong section, somebody needs to use the flag feature. Mods can't look at every thread or post to see if it's in the right place. We try, but miss some.
One more thing I noticed is starting more than one thread on the same subject. Start a thread with your problem and stick to it. Multiple threads on the same problem only dilute the chances of receiving the right answer and is confusing to you and those trying to help.
One last thing - In most of the threads you started, members ask questions. In many, I see no reply back from you. When this happens threads die. You need to show more interest in getting stuffed fixed.
Forums like this only work when we all work together and if members makes suggestions that work for you, some feedback that it helped or didn't help is nice. All we can do is guess that the last thing helped you.
