Motor started out all of a sudden it would not crank.Checked things and had no spark on any of the 3 cylinders.Replaced ignition switch and started getting spark but still will not crank.Boat is getting 12.5 volts at ignition switch and 12.5 volts at solenoid but as soon as you turn key to crank it the voltage drops to 9 volts immediately.You can hear the relay click but the motor does not try to crank.If you take a jumper and jump from the solenoid to the starter it spins over like it should.Some help from the gurus as what else to check would be appreciated.
