emsqd
- Sep 5, 2016
- 1
I have a 1984 60 HP Mercury ELPT with power Trim / Tilt. I had it on the lake last week and as I was taking the boat out of the water, the trim would not go up. The motor works, and I noticed oil/fluid spitting out from where the valve attaches to the bottom of the pump/reservoir. I did a bit of searching and it looked like it was the o rings leaking. Mine has a locking control valve and uses 4 hydraulic lines. I purchased a complete used unit to use for parts this unit did not have a control valve and only uses 2 lines) and swapped out the orings (for the top side, as my unit has a reverse locking control valve so it takes 8 o rings instead of 2 for a 2 line unit like the one I purchased.) It is still leaking.
I have just ordered a complete set of orings for both sides of the metal plate that goes between the valve and the pump.
I found an old post on this site that had some awesome videos of the exact issue I am having. unfortunately it looks like this post was never resolved.
If anyone else had or has this issue and has resolved it please reply to my post.
https://youtu.be/T0O0rw6A3OQ
https://youtu.be/yugFvD6_5FY
Thanks,
Eric
Thanks,
Eric
