Likesspace
- Aug 25, 2016
- 17
Hi guys,
As the title suggests I have a 1999 Mercury carbureted, four stroke, four cylinder outboard motor.
When I first got the motor it ran like a top.
I could go from idle to WOT with very little hesitation and I had full confidence in the motor getting me back to the marina.
Well starting a couple of days ago my confidence has started to fade. This is about a month after buying a 20' Suntracker pontoon with this motor as part of the package.
A few days ago the motor started to have a bit of a rough idle. Nothing severe, but the gates on my pontoon were starting to rattle while travelling in the no wake zone of our lake. Regardless of that fact, once I would get out of the no wake zone the motor would open up and smooth out.
Then I started to notice that the motor was running rough, even once I exited the no wake zone. Within a couple of days, the motor would run really rough until it warmed up well and then it would smooth out. This happened for a day or two and then things changed again......
For the last two days the motor is running great at an idle and at low rpm but once I try to go to WOT the motor starts to miss and hesitate. Where as before I could back off to about 3/4 throttle, now anything over about half throttle causes the motor to run REALLY rough.
The motor starts immediately whether warm or cold. Tonight I went from WOT to an idle and the motor stalled. Regardless it started right back up and ran great at idle to half throttle while going back to the marina. Anything over half throttle would induce the stuttering and missing that I've already described.
A few days ago I cleaned the ground point of the motor and also sprayed the plug wires with Gibbs brand penetrant. My reason for doing so is because the foam rubber at the back of my cowling is wet which made me think that there might be moisture entering the cowling, causing problems. Gibbs is great at displacing moisture so I figured it was worth a try.
When I first did this the motor ran great again and I thought I had solved the problem. I wasn't sure that the problem was a bad ground or that the Gibbs had done it's job. Well now, two days later the same symptoms have appeared again.
Tomorrow I'm going to try spraying the plug wires with the Gibbs spray, again. If this is a moisture/plug wire problem then it should show itself rather quickly.
If this is not the problem, I'm at a loss.
Does anyone have any ideas why this motor would go from running perfectly to running like crap, pretty much over night?
I'm hoping for something easy and inexpensive but at this point I'm ready to pull the boat from the lake and take it to our local marine repairman and getting a complete tune up.
If any of you can offer some advice it would be greatly appreciated.
Dave
Dave
