I'm trying to set the timing on my motor (serial #5385921), but I guess I just can't follow the directions correctly. I'm doing it with the 2 - 4 spark plugs grounded, the throttle cable unhooked, and TDC was found (using a piston stop tool) at 0 degrees. I've read the previous posts on the topic, and the directions posted by SpinnerBait_Nut. On my motor the throttle arm first goes to something labeled spark stop. This is the point where the cam contacts the carburetor. Is this the same as primary pickup? If so, instead of seeing the 2 or 3 degrees before TDC with the timing light while cranking the engine at this point, I saw closer to the 27 degrees for max advance that the manual says I need. When I moved the throttle past spark stop, the timing didn't seem to change at all when looking with the light. I could only see the 2 or 3 degrees before TDC with an adjustment of the idle stop screw. Thank you for any help you can give!
Jeff
Jeff
